How much power does a wind generator produce?
Re: How much power does a wind generator produce?
Postby windgat on Fri Jun 19, 2009 11:35 am
Well I remain confused. I thought that when a conductor 'cuts' magnetic flux, a voltage is induced (which results usually in a current, so in my simple mind voltage/current are interchangeable in this context).
For diagrams/simulations, you can download a 30day free trial of magnetic modeling software here: http://www.vizimag.com/ordering.htm
Postby Greystoke on Fri Jun 19, 2009 12:13 pm
windgat wrote:Well I remain confused. I thought that when a conductor 'cuts' magnetic flux, a voltage is induced (which results usually in a current, so in my simple mind voltage/current are interchangeable in this context).
If there's no load, there can't be a current. So what do you propose will happen then :?:
Postby windgat on Fri Jun 19, 2009 1:42 pm
"...in this context..." A wind generator is never run without a load. You are right (of course!) in theory, but I am thinking practically.
Postby Greystoke on Fri Jun 19, 2009 1:53 pm
OK windgat, but . .
There's no current without a voltage. Image
Postby windgat on Fri Jun 19, 2009 2:03 pm
Ok ok, I let you win that one! (mainly because of that nice icon...)
Postby windgat on Tue Aug 11, 2009 11:18 am
16.35A at about 28V = 458Watts! Not sure what the wind speed was, but it was a gusting North Wester.
Looking for magnets and 1.0mm copper wire
Postby easyas on Thu Apr 22, 2010 8:23 pm
Windgat - I am putting a windgen. together and am looking for 12 magnets and 1.0mm copper wire.
What have you surplus of ?. Reading the notes I see you do supply now and then. I have other questions
but that's another day.
EasyAS
easyas
Postby windgat on Thu Apr 22, 2010 9:28 pm
I have 46x30x10mm magnets (nickel coated), and am getting 50x20x8mm uncoated. Wire can always be arranged, usually by the kilogram.
Postby jkproperties on Wed Sep 22, 2010 12:57 pm
Windgat,
what would you rate your turbine on this site at? is this a question that can be answered?
I am in the JHB area and I am looking at wind vs sun
jkproperties
Postby windgat on Sun Sep 26, 2010 10:12 pm
It all depends on the blade size. With 1m blades, 800W should be attainable.
Postby Cat Robinson on Wed Oct 27, 2010 4:20 pm
Hi there - sorry to post a possibly unrelated question!
I am working with a new renewable energy magazine titled RenewerG and we would like to get in touch about a possible article/interview? Please feel free to delete this post afterwards :oops:
I can be reached at catr at renewerg dot co dot za.
Thanks!
Cat Robinson
Previous
Users browsing this forum: No registered users and 6 guests
